1 - 18 of 18 Posts
ok so i broke a sensor....its the one right under the center of the intake manifold that is circular and goes into the block and connects to the starter.....what is it? anyone got a part #? a website i can buy it from? how much is it?
Knock sensor. As to the other questions I don't know.
Yeah but it doesnt connect to the starter....... :rolleyes:
30530-PRB-A01 SENSOR, KNOCK
would this work 30530-PPL-A01 im guessing this is the knock sensor from the base model, its like 30 bucks instead of 50 something.....it would work all the same right?
That is the EP3, Civic Si Knock Sensor.... It does work but not sure if the harness is the same...
30530-PPL-A01
I typically use this logic... If it worked the same, why would they make 2 different ones?
Discussion Starter · #11 ·
yea but you also have to think.....honda/acura make many many parts that are interchangeable amongst their lineup of automobiles:up:
trial user
I subscribed to a thread called "The Definitive K20/24 Sensor Comparison" a while ago that was started by Froth. It has saved my shit more than once. Here is a portion of it regarding knock sensors.
Accord 04-07 Knock Sensor P/N: - 30530-PPL-A01
Civic 03-05 Knock Sensor P/N: - 30530-PPL-A01
CRV 03-07 Knock Sensor P/N: - 30530-PPL-A01
Element 03-07 Knock Sensor P/n: - 30530-PPL-A01
TSX 04-07 Knock Sensor P/N: - 30530-PPL-A01
RSX 02-06 Knock Sensor P/N: - 30530-PPL-A01
RSX-S 02-06 Knock Sensor P/N: - 30530-PRB-A01
Civic Si 06-07 Knock Sensor P/N: - 30530-PRC-003
Agreed, but there is typically a change for a reason. Sometimes its just an updated part. In terms of electronics, its sometimes a more sensitive/accurate part.
In the case of the knock sensor, I'd rather pay the extra to ensure all works as intended. Otherwise, I think I've got a k20a3 knock sensor you can have for relatively cheap.
Discussion Starter · #14 ·
could you post up a link to this thread i would greatly appreciate it.....also is he saying in his thread that all these knock sensors can be interchanged or was he just listing part numbers for everyone?
Discussion Starter · #15 ·
i may just have to buy that sensor off you, but let me do a lil more research first:D
trial user
Here is the link:
http://www.k20a.org/forum/showthread.php?t=21854&highlight=definitive
I know which motor I have so's I look at the part # for my year and see if there is another year/chassis with the same part #. I have an Acura motor so's I look up the part # on a Honda that has the same # so's I can save a buck.
1 - 18 of 18 Posts
