1 - 5 of 5 Posts
This unit is brand new, still in the box. I bought this so I could easily display all of the sensors but I bought a K-Pro which has the same features. This is perfect for anybody who wants to easily monitor the performance of their car. This is universal and plugs into your OBDII serial port. It reads directly from your ECU so it is very accurate! Use this to scan and/or erase CEL's. This is also a handy tool for recording your rev's - know exactly how high you revved during a race or mis-shift.
This unit has a RED display to match the interior lights of an RSX.
PENDING
Discussion Starter · #2 ·
Here's some more info. about the R900, taken from their website:
The R900 is a digital sensor monitor that plugs into the diagnostic port on most 1996 and later import vehicles. The data is completely accurate as it is communicated from the engine ECU. Through the selection of one of 8 different screen modes, the user can monitor engine RPM, ignition timing and the following sensors.
- TPS (Throttle Position Sensor)
- MAP (Manifold Absolute Pressure)
- MAF (Mass Air Flow)
- ECT (Engine Coolant Temperature)
- IAT (Intake Air Temperature)
- O2 (Oxygen Sensor Voltage or A/F ratio. Vehicles factory equipped with wide band oxygen sensors will always display A/F ratio)
- VSS (Vehicle Speed Sensor)
- Speed and Temperature can be displayed in Metric or English units.
- LCD can be dimmed.
- Reads and clears diagnostic trouble codes (DTC's).
- Calculates and displays boost on vehicles equipped with MAP sensors.
- 4 display color choices - White, Blue, Green or Red
- Case dimensions: 6.5"x2.75"x1".
1 - 5 of 5 Posts
