1 - 5 of 5 Posts
i have 04 accord lx going to put rear discs form an ex on do i need to change the brake master cylinder?? thanx I NEED THE HELP SOMEONE KNOWS I KNOW IT!! i have all the stuff but its a daily drive
If the brakes bolt right up or have an adapter that makes them fit, then no you don't need to change a master cylinder. I put a 13" BBK on my EP3 and didn't change anything but the brakes.
Only question is ABS. If the setup is the same. I can't answer that.
Christian
If there's ABS, if the ABS is like the EP3 then you will be fine. The ABS sensor on the EP3 runs off the axle. If yours is the same, then no problems. master cylinder is not an issue.
Christian
1 - 5 of 5 Posts
