1 - 2 of 2 Posts
Good day!
My current brakes set up is type r hydrovac, spoon monoblock with 300mm rotors and, dixcel es brakes pads up front. ebc pads at the back. steel braided hose, wilwood brake bias controller.
I feel my brakes are still weak. it feels like a small improvement from the stock 16cl brakes. I was expecting a big improvement since its Spoon brakes.
btw, I'm running an itb set up. and the air connection from the manifold to the hydrovac is connected to a Y-piece connection. it is sharing with MAF sensor (I think) could it be the problem? should I give a separate connection to the hydrovac?
thanks!
should be a 5/8's inside diameter hose that is only connected to the brake booster, and its done this way for safety so no other part can causue brake assistance failure. if your unsure of what your doing with brakes please seek professional help so you don't kill yourself or some one else.
1 - 2 of 2 Posts
