1 - 6 of 6 Posts
I recently bought a JDM K24A for my k24/20 build I'm doing right now. After I took the timing cover off, I noticed some cracks, they seem to rise above the surface a bit. I need to know if these are actually part of the block, or just a coating or something that normally wears when it's in storage.
104156
My old k20a2 block with ≈150k+ miles had some cracks that looked similar, but not nearly as many (pic for reference) and the block I just bought is much lower mileage.
104157
Anyone else had any experience like this? I really need to figure this out because I don't want to start building my engine on a compromised block, especially since I plan to boost in the future.
I did try searching this up, but I couldn't really find anything, maybe I wasn't wording it correctly.
Edit:
Took my oil pump off, and I'm seeing those hairlines inside the block too
104158
104159
Any help or advice would be greatly appreciated.
...I need to know if these are actually part of the block, or just a coating or something that normally wears when it's in storage.
If you are unsure use a simple dye penetrant test to confirm or not confirm it is a crack (s. Dye penetrant inspection - Wikipedia ). This test approach is simple, achievable and pretty reliable. I have used it for doing aftermath when engine failures occurred or were knocking on the door. Just incase you don't have trust on it, test it.
Discussion Starter #4
Casting lines. It's normal.
Yeah after asking around and I figured out what's what it was. Apparently Honda doesn't use a very good casting process. Still weird how many more casting lines my k24 has vs my k20, but it should be fine
An easy approach to check whether it is a dried oil layer or the casting itself having a crack would be to sand a 20 mm x 20 mm area where crack lines are dense and to see what happens with them a bit under its surface.
Casting lines aka "flash" is normal from my experience and isn't a large concern. Honda may not give much thought to casting but it excels at machining the final product, which is where it counts.
Mak
1 - 6 of 6 Posts
