Hey guys, I'm sure you have heard about the Borg Warner SX-E line of turbos expected to be released August 1st, 2015. I searched for a thread pertaining to them but, didn't find one so I figured I'd start one where we can compile and share info. I want to thank Full-Race Geoff, Howard Coleman from CPR and BoostLab for a lot of this info. I am in no way affiliated with Borg Warner, nor a salesman of any kind, just an enthusiast who really enjoyed the results I've seen from the EFR line such as the Sierra Sierra Evo and the fact all Indy cars moved to twin EFR7163s in 2014(can't be for no reason). The primary use of this thread is to share info on the new SX-E's, but you can compare them with other brand turbos as long as they either have similar compressor maps, wheel sizes or have been back-to-back tested on the same car. I don't want this to turn into an opinionated arguing match of Borg Warner vs Garrett vs Precision vs Whoever, let's keep it to the facts and let's keep it objective. With that said, here's what I got so far...
The new Airwerks turbos designated 'Enhanced S200/300SX' are intended for competition or racing applications. They are based upon the all-stars of the current S200 and S300 lineups but are upgraded with an all-new multipad 360* thrust bearing, the latest generation billet compressor blade aero and new compressor housings.
The SX-E line is similar in design to the EFR line but without the Blow Off Valve, Internal Wastegate, Gamma-Ti Turbine Wheel and Ball Bearing, making them way less expensive.
The dramatic difference between the typical cast SX compressor maps and the SX-E maps is increased efficiency from the compressor cover.
All S300SX-E turbos have the same size turbine wheel as the EFR9180(73mm Exducer, 80mm Inducer) except the S362SX-E that comes with the 68mm Exducer, 76mm Inducer wheel
Numbers signify Compressor Inducer size in mm(S252=52mm wheel, S257=57mm wheel, etc)
S200 Series: Available with T4 Twin Scroll 0.83, 1.00, 1.15 and 1.22 A/R Turbine Housings
S252SX-E
S257SX-E
The S257SX-E Compressor Map:
S300 Series: Available with T4 Single Scroll 0.88 or Twin Scroll 0.91 and 1.00 A/R Turbine Housings
S362SX-E (w/68mm Turbine Wheel)
S362SX-E (w/73mm Turbine Wheel)
S363SX-E
S364.5SX-E
S366SX-E
S369SX-E
The S366SX(red) compared to S366SX-E(black):
The S369SX-E Compressor Map:
From Full-Race Geoff:
"These new compressors move some air. I saw the 69mm overlayed on a GTX4294R...gives up nothing, nowhere...pretty interesting how aggressive they can get on comp wheel aero and this 80mm is one of their best turbine wheel designs to date."
My Observations:
I took a look into what he was talking about and I have to agree, the maps are pretty similar. Both turbos are good to 95lbs/950hp.
Both have ~4.9 peak Pressure Ratio(PR) at the top of the surge line. The difference is the Borg hits that peak by ~64lbs and slowly tapers down as flow increases toward the choke line. The Garrett takes until ~79lbs to hit that peak and tapers toward the choke line. This make for a wider graph at a high PR for the Borg.
Mind you, on the Compressor side, the Garrett has 94mm Exd, 68mm Ind while the Borg has 91.4mm Exd, 69mm Ind. On the Turbine side the Garrett has 82mm Ind, 75mm Exd while the Borg has 80mm Ind, 73mm Exd.
So from this you can conclude not that one is always better than the other for all scenarios, but the fact that the Borg is producing the same flow and a wider map at high PR with overall smaller wheels, it's a real contender and very well designed.
S257SX-E(also called "Enhanced S200SX-7670") from SEMA last year:
S252SX-E
S257SX-E
S363SX-E
S364.5SX-E
S366SX-E
S369SX-E
My Observations:
