1 - 18 of 18 Posts
Re: BulePrint RBC port&polish to 70mm.
Whats ur setup...if u dont mind me asking..
Thanks to Ben, and my RBC port&polished by Blue-print. I re-tuned the N/A motor from 255whp to 269whp. All air improvement on pump gas tune.
Do you happen to have a dyno graph of before and after?
:wow:That seems like a lot unless that was the final squeezing factor on your motor...I would definately like to see a graph before and after and setup before and after...Pleeeeaaaassseee
Discussion Starter · #7 ·
Ok I not a builder, so heres what I got done.
short air intake/ K&n filter
RBC manifold ported by Blueprint to 70mm. & a 70mm Karcepts adapter.
Skunk2 70mm T/B, (it was a oem 64mm)
IPS k2 cams orig. with spring set.
k20a2 head (not ported)7 Oem valves.
RDX 410cc injectors
Hytech 2.5 header
k24 block build by inlinepro.
Je 12-1 comp piston, other inf call inlinepro.
Hytech mod k20a2 oil pump.
K-pro tuned by 2NRS of Springfield MO.
Patterned after Nikos post.
12-06-2007
Complete 300whp k24a / k20a2 guide
k24a block
89mm sleeves INLINEPRO
IPS 8620 K2 mark2 cams
IPS JE 12.5:1 compression pistons
IB SPEC RODS k24a I beam
SSR HEADER FOR K20a2 motors 4-2-1
STOCK RBC with karcepts ADAPTER
STOCK THROTTLE BODY
Karcepts Intake
STOCK 99mm crank
STOCK 2006 Civic Si head
SUPERTECH spings, titanium retainers, keepers with SUPERTECH FLAT FACE VALVES
Final tune on race gas and open header
Discussion Starter · #8 ·
All I got was paper copies of the dyno's, so let me see if I can come up with them, or something to post. Most say posted dyno doesn't mean much, it's how the car runs that counts. But I drive the car as a daily driver, when the roads aren't wet. I also drive to the IFO races I run in.
Discussion Starter · #9 ·
How much did it run you to get it port and polished....?
Ok $500. or $1,600. for some top named mainifolds. The RBC ported about 330 cfm, one named manifold about 340 cfm before porting.
Upcoming k20a.org Project IPS K24A 101.6mm x 89mm
Thank you
IPS manifold alone on the flow bench was at 330 CFM average..
After port matching with the head, the mani alone flows at 394 cfm
Thank you Stefan!!!!
Jesse,
The RBC has a small plenum volume and will start maxing out at high rpm. Thats where the IPS manifold will pick up power and outrun a ported RBC.
Stefan
Banned
trust me when I say this... what a manifold flows on its own is not as important as to what it flows connected to the head...
Like I said before, you can take a big drill and make the RBC flow 500 cfm.. it doesnt mean anything on its one.
The biggest advantage I see is the volume of air that it can hold at one time.. The IPS mani's plennum is huge
Discussion Starter · #13 ·
Yes nikos, IPS manifold is a top level manifold & RBC is a med level manifold. I am giving my :up::up: to Blueprint for taking me, to my next level in intake air flow. I am happy with my up-grade. Yes there my be another level later, after porting my head & new valves. Cost for RBC from stock 64mm $250-RBC manifold, + $500-porting RBC to 70mm,+ $70.-70mm Karcepts adapter,+ $300.-70mm Shunk2 T/B = $1,120. & $500 retuned, $1,620. total for about 10-15 whp.
Next level about $1,200-port my k20a2 head, $500-new after market 1mm over valves, = $1,700.
Ohhhh, ok. That power makes sense on your motor. Is there a reason why your running a short intake? I think with a tuned length cold air you can exploit the rest of the intake setup you have... Have you gone that route already?
Discussion Starter · #18 ·
Jetlag under venders on here.
nikos's Avatar
Send a message via AIM to nikos
Default Ips manifold in production again
Hello,
we are doing another run for IPS MANIFOLD 2.4Liter version. We are only doing 10 this time around. 4 are sold already
$1600 shipped
Let me know with any questions or to order. There is no minimum order to meet.
thank you
NIkos
1 - 18 of 18 Posts
