1 - 16 of 16 Posts
I am building turbo setup and got the engine out to add sleeves and redo valves, what company makes best timing chain kits and also the timing chain tensioner.
Best timing parts for k series are oem Honda 馃憤. The tensioners are only about $90 most places. Chain will run a hundred bucks and then the 2 guides will be another 80 or so each if I remember right.
  • Honda oem Oil Chain (64L) (13441-PCX-004)
  • Honda oem Oil Chain Guide (13460-PNC-004)
  • Honda oem Oil Chain Shaft Tensioner (13450-RAA-A02)
  • Drag Cartel Chain Guide (DC-LWR-GUD)
  • Honda oem PRB TCT (14510-PRB-A01)
  • Honda oem Cam Chain Tensioner Arm Guide (14520-PNA-003)
  • Honda oem Cam Chain Guide A (14530-PNA-003)
  • Honda oem Cam Chain Guide B (14540-PRB-A01)
  • Honda oem Cam Chain Tensioner Bolt (90003-PNA-000)
86x86 Engine
this is for oem cams. for aftermarket cams i would get a different timing chain tensioner.
if you are going with heavy duty road racing get a Toda timing chain: # 14401-K20-000
you are right with your pricing. I use hondaacuraonline.com because of Glenn in customer service and their pricing is low.
Awesome guys, just ordered all of it, thanks for your help.
  • Honda oem Crankshaft Seal (43x58x7) (91212-PNC-004)
  • Honda oem Chaincase O-Ring (91302-PNA-004)
  • O-Ring, Chain Case - Acura (91302-PNA-004)
  • Oil Seal (43X58X7) (Arai) - Acura (91212-PNC-004)
  • Sensor Assembly, Crank - Acura (37500-PNB-003)- $95.88
  • Bolt, Special (6X20.5) (Guide) - Acura (90028-PNB-003)- $1.81
Discussion Starter #9
I have a Skunk2 timing chain cover arriving tomorrow, will have to see if it comes with any o rings or seals
Discussion Starter #13
Nice , I have always wanted one of those but never wanted to pony up the dough lol.
Trust me i know, i started my build in 2012 but had to put everything on hold, 3 kids later and 8 years later i have the money now to do what i always dreamed about, so now its time to finish it and have fun.
This is how i left it in 2012
Discussion Starter #14 (Edited)
Here is cover, looks pretty sweet and yea no o rings just bolts for it.
That is a nice piece. skunk can probably help you out there, they sold me 2 individual valves for my b series not long ago when I called customer service. Would be nice to be able to mess with the cam stuff without removing the crank pulley.
1 - 16 of 16 Posts
