1 - 11 of 11 Posts
I need to buy a sump baffle for a K20A2 alloy sump, reading around opinion seems to vary massively on which is best, I've heard people having problems with the clockwise drop in kit and likewise with the circuit hero type also, is there anything better on the market?
12 months and 15+ events no issues with the Clockwise Motion Baffle.
Sent from my G8141 using Tapatalk
Also, if you're going to re-use the oil pan, make sure it is completely decontaminated from oil residue. Welds don't take well on oil contaminated ally
Discussion Starter #7
Just remember that the problem with a k20 is that the oil runs up the timing chain cover on long left-hand sweepers. So as long as your pan prevents that issue, you should be good.
I'm in the UK and luckily most of our circuits run clockwise so less long left handers ;)
1 - 11 of 11 Posts
