1 - 13 of 13 Posts
trial user
Drive up to the parts store and try on a fifty two and a half belt then go from there. Do not matter if it's six rib or seven. If six put it in the grooves closest to the motor tho'.
Bumping an old thread.. I have searched for the last hour on this forum and can't seem to find a definitive answer. Should be an end all be all sticky including possible engine combos and needed belt lengths!
Engine: K24a2
Chassis: DC2
Setup: EP3 Idler setup up top. No P/S (EHPS). With A/C.
Trying to determine the correct belt length. If you have this setup running without squeaks please post up the length!
Like previously said try a 52.5 and go from there . The belt is not that hard to change tell the guy at the auto parts store what your doing .My local parts store let me take a couple of belts with me to try and bring back the ones that did not fit .
Engine: K24a2
Chassis: DC2
I am using a 65" gatorback on that setup. I have the K-Tuned idler, by the way.
I just popped my hood to confirm: Gatorback 4070653 (65.3").
It's a K24 w/ TSX crank pulley, A/C, no power steering, and K-Tuned idler. Good luck.
This helped even further, I ordered a 65" 6rib. Called back with your code realizing it was for a 7rib and now have the same belt as you!
As for your setup - it is the exact same as mine.
Thanks again, huge help you have been!
1 - 13 of 13 Posts
