21 - 40 of 46 Posts
Discussion Starter #23
02-05 Civic Si BC Racing Type BR Coilovers
The BR model is perfect for street driving and occasional road course duty.With easily accessible adjustment knobs for fine tuning your compression/rebound and separately adjustable ride Heights,having performance coilover system couldn't be any easier.You choose how low or high you want your vehicle,no preset ride height here,and our patented concave lower locking ring keeps it locked in.All of our systems come with pillowball mounts to provide the most feedback possible from your suspension and to sharpen your steering response.BC's available front and rear camber plates also allow you the perfect alighnment setup without compromise.All this while providing a strong, attractive looking coilover system.
*Mono-tube shock design
*30 levels of damping force adjustment,adjust Compression/Rebound
*Pillow ball mounts and adjustable camber paltes(where applicable)
*Separate full length height adjustable
**One year warranty
***Rebuildable
CorSport USA.
Discussion Starter #30
02-05 Civic Si BC Racing ER Series Coilovers
Our newest and most advanced model yet is the ER series coilover. It features large external reservoirs front and rear, separate rebound and compression adjustment and a twin piston design. The external reservoirs hold much more oil than the conventional coilover, allowing the coilover to operate for a much longer period of time before overheating. The external reservoirs also house the secondary piston, which allows for the fine tuning of compression. This is the perfect coilover system for the person who wants to fine tune there setup using the separate, 30-way, rebound and compression tuning dials.
Features
-External Reservoir Mono-tube shock design
-30 levels of damping force adjustment, adjusts both compression and rebound separately
-Twin piston design
-Pillowball mounts and adjustable camber plates included (where applicable)
-Adjustable rear camber plates available
-Separate full length height adjustable
-One year warranty
-Rebuildable
CorSport USA.
Discussion Starter #32
02-06 Acura RSX BC Racing Type BR Coilovers (Extreme Lowdown Version)
**One year warranty
***Rebuildable
CorSport USA.
Discussion Starter #34
02-05 Civic Si BC Racing RAM Type Coilovers
BC Racings inverted RAM model includes all of the great BR features and then takes it a notch higher. By using an inverted coilover system we move the vital damper fluid away from the detrimental heat sources to avoid overheating the fluid and causing damper fatigue under extreme conditions. The inverted setup also handles high-g loads better and is much more durable under stress situations, such as a race track. Another advantage is reducing unsprung weight by moving the heavy parts to the chassis mounting points. This is a great coilover for those looking to attack a race track, hill climb or tarmac rally.
Features
-Inverted Mono-tube shock design
-30 levels of damping force adjustment, adjust compression/rebound
-One year warranty
-Rebuildable
CorSport USA.
21 - 40 of 46 Posts
