1 - 3 of 3 Posts
hey guys n girls, i relocated my battery to my trunk and already searched on how to run the battery cables. my question is could i just run one cable from my battery to the starter and where it connects to the starter use the stock cable from there to the fusebox? instead of using two cables from the battery, 1 to the starter and 1 to the fuse box would there be any problems if i ran it like that? will i burn my starter so something? BTW my car is a 01 civic ...thanks....
i think this thread will give you a good help:
http://www.k20a.org/forum/showthread.php?t=43384
ya i read that thread but i dont see why i couldnt run the second power cable that supposed to come from the battery, from the starter instead of the battery. the stock harness only has one cable running from the battery to the fuse box then from the battery to the starter. does it matter if the two cables come from the battery or the starter?
1 - 3 of 3 Posts
