1 - 2 of 2 Posts
Hey I have a k24a3 in the UK
450 fuel pump
Gt3582
1000cc inj
4bar map sensor
50psi for
4port Mac boost solonoid
44mm wastegate
Stock block
Ep3 throttle body
Aem 30-3000 wideband
Kpro v4 ECU
Any help would be great just want to get safe driving to get to a Dyno
You are going to run a higher risk using a "similar" setup calibration. I tune engines professionally, I would recommend you trailering your car to the tuner, or let it tune from remote (idle, part load) on street.
1 - 2 of 2 Posts
