21 - 24 of 24 Posts
That looks good...but for running the risk of grinding too deep into the metal I think body filler is probably the best option. When I feel my intake after driving it's only kind of hot...not even hot enough to burn me...it's really barely hot at all.
I had the same pitting in my RBB manifold. They probably use leftover material from blocks and heads to sand cast the intake manifolds, so this happens more than you think. I used JB weld and it has been on a daily driven car for 2+ years now. I have used JB weld inside other manifolds I have ported with 7+ years of use, and there has been no issues. Make sure you acetone and alcohol the pits before applying and you are good to go.
I have not tried the JB Quick 5 minute stuff inside a manifold. It doesn't seem as strong to me. I have stuck with the regular. My new favorite AL epoxy is Lab-Metal. It's tougher than JB weld and I used to repair big aluminum castings that see very cold and hot temperature cycles. Good stuff!
You might want to try a rougher sand grit wheel on those runners. It looks too smooth in there.
As said above, unless someone can provide evidence of measureable gains, it's simply not worth it, especially for something that no one will ever see.
21 - 24 of 24 Posts
