1 - 3 of 3 Posts
What would I have to do to swap a CRV engine into a 90 Integra. From what I know that the B20B is the samething as the LS block out of my car. The Crank is the same but the bore size is different- 81 vs. 84. So my guess would to swap the intake manifold so the wiring matches. But what about the OBD0 to OBD2? Please help. PS and I dont have enough money to get a K.
Thanks Chris
Well to make it the most straightforward possible, just swap the manifolds and distributor. Use your stock engine mounts, not the B20 engine mount, and drop it in...this is a cake walk. Look into getting a B20 program and chipping your ecu. If you go on turbo edit forums there are B20 programs available. You'll figure it out man..just do it already.
1 - 3 of 3 Posts
