Axles!
ok i have spent over 1200 bucks worth of shitty crap stage blah blah axles this and that blah blah. the stage 2 axle from hasport does not fit in my eg either, it wont go into the tranny all the way, just like the other guy on here. i have tried the stage 1 from hasport, and stage 2. fitment was fine on stage 1, but they snapped. stage 2, fitment was fine on passenger side, too long on drivers side. then bought some stock b series, and stock k series. this is for an eg not sure about ek. the k series outter joint runs a 36mm hub, so unless you have a itr 5 lug you cant use the outter joint/hub. so, after all this bullshit with different axles and what not. i came to find out, the stock k series drivers side axle, with a b series outter joint/hub, fits and holds fine. and on the passenger side,(some of you prob wont even believe it), the splines that go into the half shaft and k series are identical. so i havent tried for perfect fitment yet.....but i can tell you the axles are exact same size, (aftermarket stage 1, and stock b series pass side.) so there is no reason why they shouldnt fit.
so......
(for EK with hasport mounts
drivers side- stock k series inner hub, and shaft, with outter b series hub.
pass side- stock b series outter hub, prelude shaft(92+), k series inner. )<<------------this has not been verified, try at your own risk
for EG with hasport mounts (no prelude axle needed)
pass side- stock b series outter hub, k series shaft and k series inner hub.
now how fucking easy was that after 20+wasted hours and 1200 bucks worth of axles. :evil:
so......
