1 - 20 of 20 Posts
· First in Sweden
Hi there!!
Doing an EG/K20 swap, and what I have read about axles probably OEM axles would hold up best.
As I live in Sweden we don’t have the RSX here so I wonder if the EP3 have the same axles as the RSX?
And what I understand about the OEM axles is that I need one pair of RSX/EP3 axles and one pair of DC2 axles, with some labour to make it fit, right??
· Banned
Basically, you are going to replace the part of the ep3 axles that connects to the eg wheel with the b series one and add the K series outer hub on the other b series axle.
You might have problems getting the ep3 to fit directly. In that case you are going to have to try the prelude/h22/h23 shafts.
Also consider buying them from here as well. It cost me $120 to ship a set of axles to australia form here... + the cost of the axles... So figure around $500 shipped to you for hasport/hybrid racinf or profab axles.
There is an article that will appear around june/july in honda tuning magazine. Once it is not sold anymore, I will post the complete article in here. Meanwhile, ask me whatever questions you have. I can help you but cannot post pics publically before they appear on the magazine.
nikos that was a little confusing... by hub did you mean outer cv joint????
confused....
ok, so base RSX axles are EXACTLY the same as the EP3?
how about Type S axles? ... are those the same as the EP3? ... and 04+ ep3 axles? ... the same?
manual, auto axles = the same? ... (sorry for the millions of questions, but I'm gonna be needing axles very soon and I only know that ep3 axles will work for my em2, but I wanna be able to use alternatives if I can't find ep3 ones)
· Banned
H2nr said:
so you are saying H22 shafts on both side not just the driver side
No.
for EK with hasport mounts
drivers side- stock k series inner hub, and shaft, with outter b series hub.
pass side- stock b series outter hub, prelude shaft(92+), k series inner.
for EG with hasport mounts (no prelude axle needed)
pass side- stock b series outter hub, k series shaft and k series inner hub.
nikos said:
No.
my bad man I read your last post wrong, thanks for making it clear :eek:
Nikos would this set up (k-H-B) axles work with the hybrid mounts as well or do you know?
1 - 20 of 20 Posts
