1 - 7 of 7 Posts
Hi
I am need of a little info on whether you can use an OEM UKDM EP3 TYPE R axle on a UKDM DC2 TYPE R K-swap or would i need to split the axles to make them work.
hope someone can help
thanks
Chris
do u kno the spindle size?
I think the UKDM EP3 type-r axles are 32mm but in another axle thread on here they were stated as being 36mm. Can anyone confirm?
Been in touch with Hybrid - their new generation mounts mean that you can use stock ep3 axles in a eg/dc2 chassis without having to swap inners/outers etc. I told [email protected] what my setup is and he said the ep3 axles will work so I assume the stock UKDM EP3-R axles are 32mm.
Just found out that i got my wires crossed with the new mounts from hybrid, well kind of. Basically the base model EP3 axles will fit perfectly but the type R axles wont as they are 36mm outer.
Does this now mean that any axles from a 2001 onwards EP3 fit as they should technically have 32mm outers.
if the hybrid mounts let you use those axles straight up then yes any that is 32mm. dont know specifically wut years are wut.
Me and my mate where discussing issues about the axles and he made a valid point that if i was to use OEM base axles from say a 1.6 EP3 i would then be putting say over 300hp through axles that has been designed for a lower speck car which has say only 100hp would this not just spell dissaster and a waste of money.
Is it possible to swap the outer hub on the k-series EP3 Type R hub for a b-series UK ITR DC2 so that it would suit the 36mm spline on the 5 stud hub.
I have put a shit drawing to show what i mean.
1 - 7 of 7 Posts
