1 - 20 of 115 Posts
looking for info on tires that can be daily driven but that can be tracked too. which one performs best for it's price.
for the front size: 15" between 205 to 225 something that fits on an EG chassis. price let's say under $130 per tire. as for the rear size could 195/50R15
which one has decent grip & wear
if you guys can recomend other brands & models & give your input, share experiences. that be more than welcome.
Toyo R888
Bfgoodrich R1
Advan AD08
Nitto NT01
Hankook Ventus R-S3
Dunlop Direzza Sport Z1 Star Spec
Hankook Ventus R-S2
Falken Azenis RT615
Toyo Proxes R1R
Nitto NT05
Bridgestone Potenza RE-11
Kumho Ecsta XS
the last 3 are your best bet.....the 615's are ok for dd and autoX but they get greasy on the track and the nt tires are r compound tires...not the best for dd as they are heat cycle senative and will get harder quick if you dd on them.
I'm on the xs's and I am pretty happy with them but you can not go wrong with the re11 or the z-1's....:up:
im running star specs, love them. havent tried the re-11's yet. i heard they are better than the re01r's??? but dont know. those 2 get my vote.
good info
i added the Hankook Ventus R-S2 to the list any input on that one?
I would not daily drive an r-compound. Between wear and risking picking up a nail, not worth it for such an expensive tire.
The rt-615 will work on the street, but does not hold up on track. It gets greasy in warmer temps. (Had a set, I tried...)
I now have dunlop start spec z1's for daily tires. Chose them because I wanted a street tire good enough to run on a wet track.
I use toyo r888's for track use which is very similar to the nitto nt-01 (nitto is a division of toyo).
For all around, the dunlop or nt-05 would be good choices. The new bridgestone re-11 (correct #?) is supposed to be good as well.
yeah i'm looking for something that i could track & daily drive.
not looking for R compound at the moment. later i'll get R compound for track days only.
has anyone tested this ones from hankook?
Hankook Ventus R-S2 225/45ZR15 Temp: A200 AA A Speed“W” = 168mph 51 psi
Hankook Ventus R-S3 225/45ZR15 Temp: A140 A A Speed “W” = 168mph 51 psi
Dunlop Sport Z1 Star Spec, HANDS DOWN. The RS-2 has too much water siping and loses dry traction because of this. Trust me, I've been through a LOT of tires and As far as the best Daily/Track tires you will find the Dunlop Sport Z1 Star Spec will not be beat IMO. Check the reviews, they'll back it up. http://www.tirerack.com/tires/tests...e=Dunlop&tireModel=Direzza+Sport+Z1+Star+Spec I will never use ANY other tires so long as they make these.
-Froth
the majority said star specs. but if you are sold on the hankooks then get it. cant change a mind thats already made up. :silly: its like asking for advice and not taking it. lol. :p
Discussion Starter · #9 ·
-Froth
good review
I'm not sold on the hankook rs2, i was just wondering if anyone had tried them.what caught my eye was the width 225. i was looking at their design. just like forth said is more of a wet tire.
i've been trying to get the kumho ecsta xs locally but no one has them in their computer system :down:
if i have time today since I'm installing front hardrace bushings, I'm going to stop in a couple of tire places today & see if they carry the Dunlop Sport Z1 Star Spec.
the other choice is the be Bridgestone Potenza RE-11 205/50/15
i was trying to get something as wide as possible or with a thread design with max road contact because I'm putting down 238whp & 187wtq
Wide contact patch does not make/break a tire...it can HELP but a wider less sticky tire will perform worse than a skinnier stickier tire. I had the 225/45/15 RS-2's and I sold them after a week to a friend with a Miata, much less grip than the Dunlop Z1 Star Spec's and the Dunlop only comes in a 195/55/15. I work for one of the largest tire retailers in the business outside of Tire-rack and I can tell you hands down you will be hard pressed to find a better all-around tire than the Dunlop. I've been through most all of them.
-Froth
how are the dunlop sp9000 tires?
Not even close to anything listed above, they're soft for what they are and for being so soft they don't have nearly as much grip as they should. They're good if you're looking for a comfortable ride and do some slightly spirited driving on a lighter car...but they wear too quickly to be worth the price they go for, they're currently in the process of being discontinued and re-worked if I recall correctly.
-Froth
-Froth
Dam u think they are worth 25 bucks each? I can get them on clearance from local good year dealer?
If they're for a daily, I'd say get them. If they're going on a K-swapped car and you're looking for traction look elsewhere. They're on clearance for a reason.
-Froth
-Froth
:silly:
Discussion Starter · #16 ·
i went to my local tire place & they gonna try to get the Dunlop Sport Z1 Star Spec for me on monday, if i can't get them localy then i'll order them online.
thanks for all the info.:up:
Discounttiredirect.com I got mine from here cheapest place I found because they are offering free shipping...
Also dont forget your $50 mail in rebate good until may 2
You guys are all crazy. The Star Specs SUCK. I have had 2 sets of them now and they are crap, I hate them.They are on my daily right now. I had 2 where the belts broke on me with about 30% tread left. Star specs are loud too. The Hankook Ventus R2S or RS2 (whatever it is) is way better. I had them 3 times and they were great. Azenis are too soft and greasy as mentioned. I flat spotted mine in a minor lock up, really pissed me off, took forever to wear through. I drive about anywhere from 60-200 miles A DAY. I go through tires.
re-o1r's were awesome, potenza pole position S03's are AMAZING!, hankook ventus rs2 are great, and the best cheap daily tire for all season is the kumho ecsta AST. They have been on my girl's a4 for 31,000 miles and have no camber/drag wear, and very minimal wear. They're perfect for my area which has mild rain, light snow on occaision, and hot ass summers. Awesome tires for the money.
this is all just my personal opinion, but I dunno why all the hype over the star specs. they arent even like "ok" in my book, I hate them. Grip from them is better then decent, but there are definitely tires with more grip.I felt even Azenis had better grip initially but have less life.
-Colin
You say you had two sets, Are you certain they were both Star Specs? Prior to the Star Spec being released they had the Dunlop Sport Extreme Z1 which was the exact same tire with a slight compound change. What type of vehicle were they on and what temperatures were they driven in? I'm not trying to call you out...I've just never heard a bad review on Star Specs since day one. I'd like some more insight to why you come to the conclusion as to how they suck when they work so well for everyone else. I've had the RS2's and the Star Spec's blow them away. I would honestly just like to hear more.
-Froth
1 - 20 of 115 Posts
