Your situation should be the same as mine. It's the same VSS, harness, and cluster. The only real difference is your trans will work with RSX cables and shift box without modifications, and my trans has an LSD. You will be using an 02-04 ECU with KPro?Can I run a z1 tranny with the 02-04 harness and have the s2k cluster to work? or would I need an a2 vss sensor?
