I Agreee.......Please let's try to keep the negative comments.
It would be nice to hear from people that tested both.. I am 100% certain there are out there..
I have the BP stage 3s but havent dynoed them. Its my understanding that the S2S3s are more aggressive, higher lift and worse P2V clearance. Awhile back im pretty sure Jeff from Import builders stated that the S2S3 where more of a "race" style cam that were "similair" to the IPS k10 on the high cam but not as aggressive on the low cam.Blueprint stage 3 cams wondering if anyone has theses and what numbers your getting with your setup. Am deciding between these n the sk2 stg3s
I would think that you would get the most gains out of a built motor but it could go into a stock one.Will these stage 3 cams work on a K20A or are they for K24 builds?
They will work on a K20, you will just see higher gains on the larger or more built motors.Will these stage 3 cams work on a K20A or are they for K24 builds?
