Whats the max horsepower you think can be squeezed out of
a K20.
a K20.
Future setup (not mine)ViciousKBRACING said:Whats the max horsepower you think can be squeezed out of
a K20.
Thats not a tuned motor.supafly said:Do you have pics??
Im just concerned about fitment as well as power produced.
On B series running 18 psi using straight T4 with .58 ex and int .70 averages 485whp using stand alone.
Now if info is correct 30psi with a T4 60-1 on a k series pushes 495 seems to be extremely low.
Do you have dyno sheets showing a/f. Im sorry to ask so many ?'s but it just seems on 30 psi with such a large turbo it should be being peaked out power should be around 600whp.
Is the motor built as in sleeved forged pistons lower compression etc...]
Thanks
Well higher compression is more efficient.TypeRWanter said:Hmm.. If I'm not mistaken, wouldn't a K24 be a better motor to boost?
Lower compression (stock)
and Higher Displacement...
Well yeah detnation.TypeRWanter said:Hehe..
Too high of compression ='s *BOOM*, right?![]()
