Thank you for the info I ended up swapping the 04 valves into the 06 head and it fired right up I have a misfire now that i had before it’s random and sounds like one Cylinder I ruled out coil, compression and injectors I’m stumpedYes the 06-08 head will work just fine. I've had both 04/05 and 06-08 head castings side by side and the casting is exactly the same. It's amazing how much an intake came revision and oversized intake valve could wake up an engine.
