1 - 11 of 11 Posts
· Houston area
Yes it does matter. If you want to use the ECU in a K-swap it needs to be an 02-04 ECU. The 05-06 cannot be used. Just stay away from any ECU with the last 3 digits A13 through A16
02-04 would be cheaper because the kpro would cost more to convert from the 02-04 to the 05-06 ecu's. ( for people running the z1 set up, and want to use the z1 trans and magnetic type speedo gear.
Thanks
b20vtec, any new videos dogg? i love your vids man!
Na I was recording one and the cops came so we took off and got pulled over and a chp officer took it from me.. sucks it was a brand new 1080p hd camcorder I just bought..
Discussion Starter · #8 ·
in Compton or wht
yup in cpt..
if you have a k20z1 you have to use a 02-04 type s ecu then kpro it for the speedo to work pefect , now if you have an k20a2 you can use a type r ecu with out kpro (cheaper option)
na i have a k24a4 block and im getting either a k20a2 or k20z3 head
The 05+ PRB ECU (A13-A16)can not have Kpro installed, only the reflash. When the owner of a 05+typeS wants Kpro, a older 02'-04' ECU is used with a special conversion harness that is chassis specific.
You will need new pistons as well to mount either of those heads.
Discussion Starter · #10 ·
Thanks guys that ecu i was gonna buy had the A13 as the last 3 gits thanks for the info.
1 - 11 of 11 Posts
