1 - 4 of 4 Posts
I know shit like this must get posted every other day, but my scenario I think is a bit different.
Car currently has a little under 40k on it, it's an 07 si with the ct kit making 268w and a 184wtq the clutch has been fine the last 15k miles but now 3rd gear is starting to slip a bit, barely even noticeable around 3-400rpm more than it should be. I'm going to be swapping down to a 3.1" pully soon and doing methanol and most likely tuning with an fi/c if the stage 2 setup doesn't come out soon, but what would you guys recommend?
I want something close to oem in terms of engagement, the car ideally will be making right around 290-300w without meth and hopefully 310-315 on it. thanks!
it depends if you think your going to be satisfied with that power
if your not going to be making crazy power and you want some good engagement then use a stock disc or a full face disc with a beefy pressure plate.
those 6 pucks hold power but the clutch chatter sucks monkey balls
1 - 4 of 4 Posts
