So got my kswap (k20a3) in my em2/es2, fricking amazing and a huge power improvement over the d17. But im having some issues. When accelerating the car will jerk through the powerband. Having a on off effect on the accelerator. Ive checked for vacuum leaks and even replaced the manifold gasket and throttle body gasket. The iaav is deleted, i have a brand new OEM iacv and a (Acuity?) TPS and the problem still persists. There are absolutely no vacuum or exhaust leaks. The only time the engine doesnt do it is when im at WOT, smooth powerband over all. And i should add that im getting a p1164 code. It will idle smooth then rough, then smooth again, then rough back to smooth. New plugs and 40psi at the rail.
Okay update, i went out for lunch and the car ran sooooo smooth!! Gosh it was so amazing. No jerking but just all the power at once no hesitation. Then the check engine light came back on with a Primary O2 no signal low voltage. I looked at live data and the sensor was at 0v. This sensor is new, its a denso off amazon. Maybe it was a knock off sensor? But the car was running so good. Parked it and started it back up, idle was the same as before and the jerking is back. The voltage is now showing back on the live data. Maybe its the O2 sensor? Maybe? Honda wants $450 for a oem one, ordered one off of K-series parts for $230. Ima see what this'll doo! Anyone have insight? Any thoughts or suggestions?
I will check it over again, every connection is soldered and shrink wrapped. But i will check everything again. I will try unplugging it and see if the idle smooths like it did. I will update later when im off work.
UPDATE: Got home and double checked the O2 wires. All seems good.. but on my way home i got the good 'ol P1164 code. Making me think its really the O2 sensor, I've been looking at O2 percentages and they'll jump from -4.7% to 39.6% at idle.
If you've verified all the wiring it points to a bad sensor. I really wouldn't go to a parts store and pick one up. Honda's seem to be a little picky and only like quality sensors.
New OEM sensor solved the issue!! Oh my GOD it runs so smoooooooth. Idles smooth and all!! New code tho P0325 knock sensor circuit 1. Gonna look into this issue now.
I had my knock sensor go bad not too long after my swap. Verify wiring again, but that sensor is a lot cheaper.
Related Threads
2M posts
94.7K members
Since 2000
