1 - 20 of 23 Posts
Hi,
I wrote an android app to datalog KPro ecu's, there are more info bellow.
What do you think about?
https://play.google.com/store/apps/details?id=br.com.finxco.sdash.kpro
Description
SDash is digital customizable dashboard to display live data coming from an Hondata® K-Pro plug-in module.
See what your car is doing in real time using your android device, without the need of a computer!
*** Build your own dashboard using more than 60 available analog gauges, digital gauges and widgets! ***
Supported sensors:
• ECU error codes
• Engine speed (RPM)
• Ignition advance
• Battery voltage
• Throttle position sensor
• Air/fuel ratio
• Gear
• Speed
• Short term fuel trim
• Long term fuel trim
• Engine coolant temperature
• Intake air temperature
• Manifold absolute pressure
• Wideband voltage
• VTEC
• Check engine light
• Service connector switch
• Air conditioning switch
• VTEC pressure switch
• Secondary oxygen sensor
• Actual VTC cam angle
• Commanded VTC cam angle
• Calculated load value
• Knock count
• Target air/fuel ratio
• Reverse lock
• Brake switch
• Air conditioning clutch
• Electric power steering
• Fuel relay
• Radiator fan clutch
• N20 Arm 1
• N20 On 1
• N20 Arm 2
• N20 On 2
This application requires additional hardware in order to work:
• ECU with Hondata® K-Pro installed.
• USB-OTG Compatible android device
• USB Cable to connect to your device.
Support:
• If you face any issue or have any request, don't hesitate to contact by e-mail [email protected].
Discussion Starter #16
Hey Guys!
I published a new update a few days ago with some features:
* Record/export data logs
* Multiple dashboards - you can change the active dashboard with a single finger swipe
* Below/above alert
* You can change the color of the widgets
* Configurable shift light - with 3 phases
* Configurable red line on the s2000 RPM widget
Hope you enjoy it! :)
Best Regards,
Rafael
Discussion Starter #18
Not yet... :(
I want to build a new app compatible with all Bluetooth enabled hondata products (kpro4, s300v3 and flash pro).
Best regards,
Rafael
1 - 20 of 23 Posts
