Hey all. Got to do some pulls today and immediately noticed voltage dropping at high rpm’s.
My setup:
2000 civic with k20
Autozone rsx-s alternator
Ktuned ac/ps delete kit (belt is tight)
Hondata kprov4
DIY charge harness
Odyssey p680
Spal fan/deatschwerks dw400 pump/headlights pull lots of load.
Anyone have any guidance? I refuse to believe that my battery/alternator are too small. I have the same pump/fan/battery in the same chassis with Hondata s300 no issues.
I’m thinking of removing the alt-c cable (#b18) or following this step I saw on a forum: “The ELD circuit is pretty easy to fool. Pull the ELD out and use a 600-800 ohm resistor to ground and the ECM thinks the car's current load is high (forcing C to keep the alternator in high mode).”
My setup:
2000 civic with k20
Hondata kprov4
DIY charge harness
Odyssey p680
