this is a mix of allmotor and forced induction so i just put it in general section. i am a big fan of all-motor. but when it comes to overall speed, boost owns. so i was thinking strap a supercharger with a a/c style clutch to it. but then, arent he high-profile lobes bad for boost? so in a way, the low-rpm lobes would work better for boost? if so, is there a way to set up a switch that when the supercharger is engaged the switch will also disable the high-rpm lobes?
also, would it be possible to make the switch also change the fuel map to compensate for boost, etc.?
