1 - 20 of 32 Posts
Banned
Just need to hear some feedback on this and suggestions
k24a block
12.5 compression (Cp, Arias, Wiseco pistons 87mm)
Rods (eagle or crower)
Stock Crank
Stock Sleeves
k20a2 head
Cl9 manifold or Custom
IPS K2 cams or similar cams with appropriate valvetrain
K pro
Nice header
Any opinions on this?
Do you think the bore should go more than 87mm?
Suggested work done to the head? What size valves would do the trick?
Thanks,
NIkos
Banned
If I were to go with an allmotor K24 I think I would get it sleeved. Just because of the fairly extreme piston sideloads the motor is going to see with the super-long stroke. Otherwise I would be concerned about damaging the stock sleeves.
I agree with all the work you doing why not go a little farther. Better to be safe than sorry. I believe the stock sleeves are strong enough, but an aftermarket one would be stronger.
Banned
What about the intake manifold? The ITR might not be the best for the IPS cams. What is the best choice and where can I find it?
Edo mentions the RBC intake manifold.. From what car is this?
Banned
Well I think the ideal solution would be ITBs but you would need a fairly long "trumpet" length to tune them for the RPM range where this motor will make power, and at that point you would run into hood clearance issues...
Banned
Discussion Starter · #7 ·
Man... I wasted 1 hour looking for this manifold... no luck... How come noone is selling it? Ron, you know how we can get a hold of one?
How much better does it flow than the ITR? I know there are fitment issues with the DC5 hood but at this point I am interested in how much better it flows than the ITR one.
Thanks,
Nikos
Thanks,
Nikos
On the motor we tested it on, the manifold was worth ~17hp, going from PRC to RBC. This was in an EG, so we haven't dealt with RSX fitment issues yet. Greg from Hondawerx is in the process of sorting this out for the DC5.
-Ron
-Ron
:shock: - I am interested in buying one too :twisted:
Banned
Discussion Starter · #11 ·
Thanks,
Nikos
-Ron
Good news,
Will it fit in a EG with a K ?
One of the best way to get power Out of that motor is...
ITB's....You need that...Stock Manifold is fine but not for the top end that you are looking for...
ITB's is one of the best way for Power and TQ....
1 - 20 of 32 Posts
