I lot of people say "the K is too much $$$ , I will stick with the B"
If you have a All Motor B series engine or you are thinking about buying one, it is a no brainer for me. A K20a will give you more power and will cost less and basically where an average B series setup ends, a K setup begins.
Let;s take a look at this B series setup
b18c1 w/ a.e.b.s. t-sleeves
86mm ross pistons 12.5:1 compession
manley rods
a.e.b.s. main/head studs
b16 head with stage 7 d.p.r. port work
welded and reshaped chambers
ferrerra valves
dpr valve springs w/ crower retainers
crower custum ground camshafts
hytech header (thick tubing)
toda cam gears/toda timing belt
rc 440cc injectors
ericks racing 72mm throttle body
type r mainfold port matched to head
toda flywheel
msd digital 7
wahlbro 255 fuel pump
cometic head gasket
hondata intake manifold gasket
hondata s200
p28 ecu
93 gsr cable tranny
xs fuel pressure reguator
pro drive oil pump gear
moroso oil pan
Here;s the dyno run
220 whp /148 tq
The cost list the owner gave out looks like this.
COST DOESN"T ACCOUNT FOR THE INITIAL ENGINE, TRANNY, LABOR,
a.e.b.s. sleeves-800
a.e.b.s. head and main studs-180
ross pistons 12.5:1 86mm-600
manley rods-495
dpr stage 7 head-2300
valves-300
cams-900
cam gears-300
toda timing belt-150
hytech header-1400
rc injectors-225
intake manifold-160
ericks racing throttlebody-300
pro drive oil pump gear-300
moroso oil pan-200
moroso oil pickup-80
hondata-400
balance&blueprinting 250
$9,285 again without labor install, gaskets, etc...
Like I said, it is a no brainer to me. This b series motor still has some potential but it is very limited...
On the other hand, a k20a2 type S motor can give you the same numbers with I/H/E K pro and some good tuning. Assuming the k20a2 is on a hybrid car because the RSX headers are very restrictive due to their design.
Not trying to put down the N/A B series people... I would love to have one but I don;t see the point starting a 10K B series project when for the same money you can have a K20a/k20a2/k24a-k20a frank.
End of rant
manley rods
ferrerra valves
rc 440cc injectors
toda flywheel
msd digital 7
cometic head gasket
hondata s200
p28 ecu
93 gsr cable tranny
moroso oil pan
Here;s the dyno run
220 whp /148 tq
manley rods-495
valves-300
cams-900
cam gears-300
hytech header-1400
rc injectors-225
intake manifold-160
moroso oil pan-200
hondata-400
End of rant
