1 - 10 of 10 Posts
what do you mean fit?....proportionately it will fit....an eg is just a little bigger than a six inch filter...
are you running -10 an lines?...my bet is you have -8 an lines....therefore a -8 an filter might be easier and cleaner
i dont know what lines i'm running sorry im new to this but i'm probably going to be running steel braided lines. I just dont have a fuel filter for my swap so i'm seeing which one i should get
didn't see anything about a fuel filter thanks for the help though does anyone else know?
i found a few links in the link that rbsjnh posted.. look in the engine section
DIY Section:
Engine
How to lock VTC at 50 degrees -DCK24
A brief tour of how to check clearances in your motor -chunky`
HOW TO INSTALL CAMS by K series.com -rsxmachine
Supercharger + Nitrous: A Users Guide -Oside Jimc
How to Build a block : Excellent Info -Jeff Evans
DIY: Modify K-Series Injectors to flow 490cc and 520cc -xproductionz
FUEL SYSTEM PARTS LIST -nikos and NickZED
DIY: How to make fuel lines -blue92da
Reusing the stock fuel rail fitting - [How To: Pic intensive] -Froth
Use TSX mani on a K24A1 -Froth
How To: Electro Hydraulic Power Steering -Rubber Chicken
How to take off the K20 Intake Manifold -sspem2
In-Car Headswap, Semi How-To. K24/20 Frank -Froth
P/S into K20 EG Writeup -Karcepts
P/S into K20 EK Writeup -drhonda
DIY: Oil Catch Can for Under 20 Bucks -98specR
DIY:K-Series Camshafts Installation -rsxmachine
K24a2 meets Type S Oil Pump w/pics -suprfast
1 - 10 of 10 Posts
