1 - 2 of 2 Posts
I ran 1-2 then I felt the power bog and heard the car make like a electrical power down type noise...
Wont start, towed home..
P1362 TDC sensor no signal
P0113 IAT sensor high voltage
P0340 CMP sensor no signal
Reseted the ECU already by fuse
Tried another ECU map
Checked connections to sensors and plugged them back on
Car was driving perfectly... So I do not think its the pulse plates...
Thanks
Andre
Discussion Starter #2
Roller rockers broke at the VTEC lobe middle rollers.... 2 broke on the intake side.
Chain came off the crank? tensioner failed?? thats the confusing part...
1 - 2 of 2 Posts
