161 - 180 of 181 Posts
Re: ZDX Big Bore DBW Throttle Body
How easily are these installing in 9th gen civics? And what sort of gains are folks seeing with this?
Thanks!
Discussion Starter · #164 ·
Thanks!
The P2R adapter with your stock mainfold has some clearence issues. They are making a revised version as we speak. This does work on your car if you use a RBC manifold or something similar.
Discussion Starter · #167 ·
Hello!! Can i use this j37 with my skunk2 intake manifold with an adapter right??
absolutely, the Skunk manifold is just a RBC manifold design with a 70mm opening, use the P389 70mm adapter, plenty in stock
Do these throttle bodies work on a Subaru? The plug in/actuator looks mighty familiar. Thanks
I think they work on the EVOX but not sure if they work on the Subbies... They might, you should check out NASIOC.
