281 - 300 of 327 Posts
Discussion Starter · #281 ·
Re: Rsx-s oil pump conversions $249 shipped
Installing my pump tomorrow onto a k24a2 block, does anyone know the torque spec for the sealing bolt? Also ive seen that there is another hole that needs to be tapped and plugged? Ive seen some people do it and some dont. any help is greatly appreciated.
Just make sure it's tight.
Some blocks have a threaded jet, some not. Both size bolts are in the kit.
The ones not threaded, check out Nikos' "Sticky" 300whp build in the engine section, plenty of pictures
...doesn't give a shit.
The two 8mm bolts are 16 lb/ft and the 6mm bolt is 8.7 lb/ft. Hope that helps.
Thank you for the replies. This k24a2 had threads in the hole so that was good.
