21 - 40 of 58 Posts
Discussion Starter · #24 · (Edited)
Re: RRC oil pump conversion
I know the RBC has a mounting location for the rear engine mount integrated into the pan. Not sure if the RRC does. Might be the difference though
basically correct yes, the 8th Gen SI has an engine mounting point on the pan for a mount, the K20Z3 engine oil pan is a RRC oil pan for those who havent looked that up before.
Discussion Starter · #28 ·
Hey is this kit still available
We are trying to get some in , but no ETA right now
What problems do you have if i run a stock K24A3 sump with an FD2 oil pump!!
since this pickup low deeper I would highly reccommend a RRC pan also, which those are readily available and in stock
can this kit be used with a prb oil pan ? or must be an Rrc ?
and does this pump have a better flow capacity at higher rpm over the type s oil pump ?
No!
21 - 40 of 58 Posts
