181 - 200 of 221 Posts
Re: J35 DBW throttle bodies - 8thgen SI
I have received mine, thanks Ryan !
One question about the P2R MAP to Vacuum adapter, I can't screw that golden part more than half way into that aluminum part, is is design intent ?
https://www.dropbox.com/s/4s0o09ga4yho8w9/P2R-adapter.jpg
I did but still don't get it, sorry ?
Isn't this what you're talking about, the fitting not sitting flush with the aluminum piece?
Yes I've put also a picture in my question post, too , this one
Is it designed not to screw the whole part in ? (the golden part into the aluminum part) - sorry my English is not good.
I did noticed that picture you post, but it doesn't have any explanation.
The threads are more than likely tapered meaning the tighter it gets the harder it will seal up, removing the need for sealant, orings or a gasket.
it will likely not thread in all the way.
Got it, thanks ! :)
Hey I was wondering if the Tb actually came with the "electronic Throttle Module" Honda wants to charge me 700 for what they think is the problem. Please let me know =(
Discussion Starter · #191 ·
What are you talking about? Someone is wanting inside your wallet bud.
we sell this kit for $150 shipped, im sorry but a $700 part is not included and or needed.
lmk whats going on
Hey ryan pm me the price for the fitting slso I notice the rrc and the J35 tb have very similar bore size
Discussion Starter · #194 ·
I have RRC throttle bodies used in great condition and new J35 throttle bodies. they are exactly the same size basically so yes the J35 works perfectly on the RRC, this kit comes with the fitting, lmk what you need
also check out www.afhKparts.com
any questions lmk or pm me
-Ryan
Discussion Starter · #196 ·
I just need the fitting do I need a spacer to run the tb
A spacer isn't required.
The fitting is instock, I'm on my phone atm or I would copy a link. But it's posted on afhKparts.com
Under the P2R section. P005 is the part number
does this throttle body work with k swaps? and does it include all sensors like the tps,map,?
