21 - 36 of 36 Posts
Discussion Starter #22
AEM Wideband O2 Air/Fuel UEGO Gauge
OVERVIEW
AEM’s legendary Wideband O2 Air/Fuel UEGO Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. This gauge-type controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. All AEM digital gauges feature a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
FAST, ACCURATE AIR/FUEL DATA
AEM's World-famous Wideband O2 Air/Fuel UEGO (Universal Exhaust Gas Oxygen, “you-way-go”) Gauge is a must for anyone looking to maximize engine power and safety. When tuning an engine, accurate air/fuel ratio data is critical. Running rich can cause a loss in power, while running too lean may result in serious engine damage. The AEM Wideband O2 Air/Fuel UEGO Gauge features large LED numerals that can quickly alert the user to even a .1 change in air/fuel ratio, providing time to shut down an engine before damage occurs.
Each gauge comes with interchangeable black & silver bezels and black and white gauge faceplates for multiple color combinations.
The Bosch 4.2LSU sensor, which gives the controller its speed and accuracy, is laboratory calibrated at the factory and never requires free air calibration when used with an AEM Controller!
KEY FEATURES
No free air calibration required - ever
Accurate to .1 AFR
Includes white and black gauge faces
Includes black and silver interchangeable bezels
Includes Bosch 4.2 sensor for optimum accuracy and reliability
0-5v analog output included for use with data loggers and virtually any engine management system
0-5v analog output Gasoline values from 10 to 20:1 AFR
0-5v analog output E85 values from 6.6 to 13.2 AFR
0-5v analog output Ethanol values from 6.14 to 12.3:1 AFR
0-5v analog output Methanol values from 4.4 to 8.8:1 AFR
0-5v analog output Lambda values from .68 to 1.36:1
CorSport USA.
Discussion Starter #23
AEM Air Pressure Gauge 0-100PSI with Analog Face
WHAT IT DOES
AEM’s 0-100PSI Air Pressure Gauge unites unsurpassed accuracy, speed and control with an easy to read, analog interface. The AEM analog gauge also offer a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.*
WHY YOU WANT ONE
The 100PSI Air Pressure Gauge is a must for anyone with an on board compressor - like trucks and RVs. A drop is air pressure can result in the trailer brakes dragging or even locking up or suspensions becoming too soft and handling unpredictable. The 320 degrees of resolution makes it easy to see when there's even a 2 PSI change in pressure, giving you time to shut things down before damage occurs. The lightning fast needle movement is a result of a precision high speed electronic stepper motor making it one of the fastest and most accurate gauges available. A 100PSIG brass sensor gives the gauge its accuracy. The backlighting is user adjustable to 7 colors, allowing users to easily match the Air Pressure gauge to most factory gauge clusters. Each gauge comes with interchangeable black & silver bezels and black and white gauge faceplates for multiple color combinations.
PRODUCT FEATURES
Gauge Readout from 0 to 100PSI
Adjustable backlighting via a dial on the back of the gauge
Includes black and silver interchangeable bezels and white and black faceplates
320 degree viewing area for unsurpassed resolution
Pressure gauge includes AEM 100PSIG brass sensor
CorSport USA.
Discussion Starter #24
AEM Digital Boost Gauge 50 psi
WHAT IT DOES
AEM’s Digital 50PSI Boost Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. AEM digital gauges also offer a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.*
WHY YOU WANT ONE
The AEM 50PSI Boost Gauge gives an easy to read numerical digital readout that increments every 1 PSI to anyone wanting to know exactly how much boost they are running. All AEM digital gauges have the digital readout in the center, and sweeping LED "needle" that lines the edge of the gauge as boost changes. The digital readout will automatically increase and decrease in intensity due to the built in ambient light sensing photocell. A 75 PSIa brass sensor gives the gauge its accuracy. Each gauge comes with interchangeable black & silver bezels and black and white gauge faceplates for multiple color combinations.
PRODUCT FEATURES
Gauge Readout from -30 to 50PSI
Boost gauge includes AEM 75PSIa brass sensor
If you are running less than 35PSI of boost, use our 0 to 35PSI Gauge (PN# 30-4406 ).
CorSport USA.
21 - 36 of 36 Posts
