1 - 20 of 36 Posts
AEM Analog Wideband Air / Fuel Gauge
WHAT IT DOES: AEM’s wideband air/fuel gauge unites unsurpassed accuracy, speed and control with an easy to read, analog interface. The AEM wideband also offers a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC. WHY YOU WANT ONE: The system features a Bosch sensor with an accuracy of .1 AFR, making it among the fastest and most accurate widebands available. The backlighting is user adjustable to 7 colors, (white, blue, green, red, orange, light blue, and aqua), allowing users to easily match the wideband gauge to most factory gauge clusters. Features: Accurate to .1 AFR Adjustable backlighting via a dial on the back of the gauge Two status lights for error detection and operating status Available in white or black gauge faces Includes black and silver interchangeable bezels 320 degree viewing area for unsurpassed resolution Includes Bosch sensor for optimum accuracy and reliability 0-5v analog output included for use with data loggers and virtually any engine management system
CorSport USA.
AEM Wideband UEGO Controller
A wideband UEGO sensor controller accurately monitors Air/Fuel ratios (AFR) during the tuning process to prevent a lean fuel mixture, which could lead to engine damage. AEM has combined its single-channel wideband UEGO controller and gauge display into one unit, uniting unsurpassed AFR accuracy and control with an easy-to-read interface. AEM’s Gauge-Type Wideband UEGO Controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere.
Ideal AFR monitoring tool for EFI and carbureted applications, and engine dynamometers
Does not oscillate AFR reading like narrow band sensors
No laptop required for monitoring!
Bosch sensor included
Accurate to 0.1 AFR
Reads in AFR or Lambda via a switch in back of gauge housing
24 Color-coded LED display lights provide immediate reference to engine’s air/fuel ratio (AFR) or Lambda ratio
Integrated three-digit display reveals AFR or Lambda in real time
User-programmable 0-5v analog output included for use with data loggers and virtually any engine management system
Serial data stream included for output of AFR (RS 232)
CorSport USA.
Discussion Starter #4
AEM Analog Boost Pressure Gauge 0-15PSI
WHAT IT DOES
AEM’s 0-15PSI Boost Gauge unites unsurpassed accuracy, speed and control with an easy to read, analog interface. The AEM analog gauge also offer a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.*
WHY YOU WANT ONE
The AEM 15PSI Boost Gauge is perfect for turbo and supercharged vehicles that are running up to 15 PSI of boost. The 320 degrees of resolution is dedicated to just 15PSI, making it very easy to recognize to the exact PSI how much boost you are running. The lightning fast needle movement is a result of a precision high speed electronic stepper motor making it one of the fastest and most accurate gauges available. A 15PSIG brass sensor gives the gauge its accuracy. The backlighting is user adjustable to 7 colors, allowing users to easily match the AEM boost gauge to most factory gauge clusters. Each gauge comes with interchangeable black & silver bezels and black and white gauge faceplates for multiple color combinations.
PRODUCT FEATURES
Gauge Readout from 0 to 15PSI
Includes black and silver interchangeable bezels and black and white faceplates
Boost gauge includes AEM 15PSIG brass sensor
CorSport USA.
With the bosch sensor on the AEM wideband, I wouldn't need the OEM 02 sensor with the gauge?
Discussion Starter #10
AEM Oil Pressure Display Gauge 0 to 100 psi
WHAT IT DOES
AEM’s Digital Oil Pressure Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital LED interface. AEM digital gauges also offer a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.*
WHY YOU WANT ONE
The AEM 100PSI Oil Pressure Gauge has a bright LED display that shows oil pressure in 1 PSI increments, and a sweeping LED "needle" that lines the edge as oil pressure changes from 0 to 100. One of the most vital things to know about your engine is it's oil pressure - and now you'll be able to see and log to the exact PSI. Each gauge includes interchangable silver and black bezels and black and white faceplates to personalize the look of your gauge - it's like having 4 gauges in 1!
Gauge pressure range 0-100psi
Includes easy-to-install harness and sensor
Complete stand alone gauge requires no additional sensors or programs to operate
Ideal for both fuel injected and carbureted motors
LED displays provide precise reference to critical operating conditions and alert driver of potentially damaging operating conditions
Includes 0-5V analog output for routing to engine management system or data logger
Easy to read faceplates/displays are designed to complement existing AEM gauge styles
Included bezels and face plates allow you to personalize the look of your gauge
CorSport USA.
Discussion Starter #11
AEM Digital Boost Gauge 50 psi
WHAT IT DOES
AEM’s Digital 50PSI Boost Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. AEM digital gauges also offer a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.*
WHY YOU WANT ONE
The AEM 50PSI Boost Gauge gives an easy to read numerical digital readout that increments every 1 PSI to anyone wanting to know exactly how much boost they are running. All AEM digital gauges have the digital readout in the center, and sweeping LED "needle" that lines the edge of the gauge as boost changes. The digital readout will automatically increase and decrease in intensity due to the built in ambient light sensing photocell. A 75 PSIa brass sensor gives the gauge its accuracy. Each gauge comes with interchangeable black & silver bezels and black and white gauge faceplates for multiple color combinations.
PRODUCT FEATURES
Gauge Readout from -30 to 50PSI
Includes black and silver interchangeable bezels and white and black faceplates
Boost gauge includes AEM 75PSIa brass sensor
0-5v analog output included for use with data loggers and virtually any engine management system *
If you are running less than 35PSI of boost, use our 0 to 35PSI Gauge (PN# 30-4406 ).
CorSport USA.
Discussion Starter #14
AEM Wideband O2 Air/Fuel UEGO Gauge
OVERVIEW
AEM’s legendary Wideband O2 Air/Fuel UEGO Gauge unites unsurpassed accuracy, speed and control with an easy to read, digital interface. This gauge-type controller features a digital LED display and sweeping LED “needle” that changes colors as AFR changes from rich to lean. The unit’s 52mm (2-1/16”) gauge housing fits in most gauge pods and can be remotely mounted virtually anywhere. All AEM digital gauges feature a 0-5v analog output for use with data loggers and virtually any engine management system, such as the AEM EMS or FIC.
FAST, ACCURATE AIR/FUEL DATA
AEM's World-famous Wideband O2 Air/Fuel UEGO (Universal Exhaust Gas Oxygen, “you-way-go”) Gauge is a must for anyone looking to maximize engine power and safety. When tuning an engine, accurate air/fuel ratio data is critical. Running rich can cause a loss in power, while running too lean may result in serious engine damage. The AEM Wideband O2 Air/Fuel UEGO Gauge features large LED numerals that can quickly alert the user to even a .1 change in air/fuel ratio, providing time to shut down an engine before damage occurs.
The Bosch 4.2LSU sensor, which gives the controller its speed and accuracy, is laboratory calibrated at the factory and never requires free air calibration when used with an AEM Controller!
KEY FEATURES
No free air calibration required - ever
Accurate to .1 AFR
Includes white and black gauge faces
Includes Bosch 4.2 sensor for optimum accuracy and reliability
0-5v analog output Gasoline values from 10 to 20:1 AFR
0-5v analog output E85 values from 6.6 to 13.2 AFR
0-5v analog output Ethanol values from 6.14 to 12.3:1 AFR
0-5v analog output Methanol values from 4.4 to 8.8:1 AFR
0-5v analog output Lambda values from .68 to 1.36:1
CorSport USA.
Discussion Starter #19
AEM TRU-BOOST - Boost Controller Gauge
WHAT IT DOES
AEM’s TRU-BOOST Gauge-Type Controller is an electronic boost controller that combines the simplicity of a manual boost controller with the added ease of adjusting boost levels through a gauge interface. There is no external interface required for set up, and it is fully functional right out of the box. There are no gimmicks or special software programs included. If you want more boost press the button on the right of the gauge face, and if you want less boost press the button on the left of the gauge face. It’s that simple, and IT WORKS! *
WHY YOU WANT ONE
AEM’s TRU-BOOST Gauge-Type Controller includes everything you need, including an on-board 29 PSIg pressure sensor, built-in Overboost protection with two timed shutdown levels, a scramble boost setting and a low-side output for a warning light. AEM offers a 75 PSIa boost sensor for high boost applications (sold separately).*
AEM’s boost control solenoid (included) is the only one specifically manufactured for automotive boost applications, which means it won’t corrode and stick from exposure to rich fuel mixtures, it is pressure tested to 100 psi and includes -4 AN fittings to eliminate any chance of leaks.
PRODUCT FEATURES
No external interface required for programming!
Complete system includes harness, boost hose, on-board 29 PSIg pressure sensor (external 75 PSIa optional), boost solenoid, gauge display and all necessary fittings
Quick connect technology eases the installation process
Two user selectable boost settings with peak boost memory
Scramble boost setting allows user to momentarily change boost levels
User selectable Overboost alarm includes two timed shutdown levels at 10% and 20% Overboost
User configurable gauge includes 24 scalable LEDs, and interchangeable bezel, pin guide and faceplate to customize look of display
One (1) low-side output included for warning lights
NOTE: AEM holds no responsibility for any engine damage that results from the misuse of this product!
CorSport USA.
1 - 20 of 36 Posts
