http://www.aempower.com/rsx/
click on dyno and then click on picture 9.
This is the first time ive seen this for a K20A. Are there any benefits to running that coilpack? I notice lots of B-series guys like to add uprated coilpacks(mainly MSDs), but you guys think itll gain some power/response on a K20A?
Key Features:
- A complete Capacitive Discharge Ignition System conversion in one unit!
- Switch-controlled rev limiter (0-24,700 RPM with 100
RPM resolution)
- Built-in 2-Step rev limiter (50 RPM resolution)
- Switch-controlled ignition retard up to 63 degrees retard!
- Multi-strike capability, which can be disabled for
accurate verification of engine timing
- Coils feature .3 ohms primary resistance, 6k ohms
secondary resistance and 3.4mH inductance
- Low current draw (Two-Channel requires 4.0 amps at
7,000 RPM)
- 189 mJ primary spark energy/54,000 volts of spark plug
voltage
