1 - 3 of 3 Posts
ok i know that the rsx engine uses one single belt to pull everything , now my question is all you guys with the swap done already , is the ac compressor still in place for the belt to fit? or you taken it out.
on my swap i removed the ac compressor and still use the power steering pump. Used a 54in 6 rib belt form autozone. I know i'm suppose to run a 7 rib, But they didn't have it. I plan to run a\c in the summer so that will be obviously the oem size i will need.
it's taken out and you have to run a shorter serpentine belt (obviously) once its removed. Not sure what you gotta do plumbing-wise if you wanna retain the A/C compressor for A/C use though...
1 - 3 of 3 Posts
