1 - 9 of 9 Posts
hey
i got 02 civic si
ima using it as a track car and i wanna remove the abs pump.
if i remove it how should i route the brake lines??
thanks in advance
why are you removing it?
just take off the sensors by the wheel hubs. then you can follow the lines to whatever else is part of the system... I think there is an ABS electronic control box or something. I know when I got my 5 lug swap it had all the sensors on the arms, I just took them off. i have only flat spotted one set of tires trying to master the thresh-hold braking ability...
:cool:
ABS is for weenies :silly:
1 - 9 of 9 Posts
