1 - 6 of 6 Posts
Ok so I've been looking around the site, and I've noticed that basically everyone goes the path of no P/S no A/C.
I'm pretty sure there's a write up thread I just haven't been able to come across it/them.
What has to be done to keep P/S and A/C in an EG Chassis?
I know about the complications with the P/S pulley and a few other things, just seeking info from someone/people that know.
Also is it possible to keep Cruise control?
searching may help, There is a couple of write-ups about power steering on here, and Hybrid Racing sells A/C lines for EG's and DC2's.
he is right 100%...search for diy/faq....its in there....promise
I know you?
no, I was speaking to becoming, he is a supporting member who has been here a while...he doesnt post much...he gave you all the info necessary....
BTW Welcome to the site....
http://www.k20a.org/forum/showthread.php?t=53589
look in this thread
Depends if your civic has PS already set up...
For my integra, I got the high pressure PS hose from an RSX type S. Be careful, I remember reading that not all PS hose from an RSX is the same. I used the stock PS pulley from rsx because it did not get in the way of my hood. Routed the powersteering hose just as it was routed originally on the b series. You should be able to find schematics online or even acuraautomotiveparts.org.
If you don't have PS rack on your civic you will need to get one. One from an 94-01 integra will bolt right up.
Some people put oil coolers, but I didn't because I didn't see any problems. I do have an oil cooler however, just haven't had the chance to install it yet.
Not sure if I'm missing anything. Hopefully others can comment.
1 - 6 of 6 Posts
