Which radiator hoses will i need for using stock relocated ek radiator?
-I've heard multiple solutions, trying to find easiest and what works.
O2 sensors? Is it possible to use an O2 simulator or do i need the ones from an RSX or is there another solution to this? Will k-pro disable these? Little confused here.
2002 ep3 throttle cable? yes or alternate solution?
Shifter cables? Are tsx shifter cables longer than rsx ones?
Thanks for all the replies, trying to figure out the small details.
