Ok, to start things off, my short block consists of a Golden Eagle sleeved k24a8 block with an a1 crankshaft, balanced Eagle H beam rods, Manley 87mm 11.5:1 ceramic coated pistons, Fluidampr crank pulley, k20a2 oil pump, Clockwise Motion baffle, z3 pan and ACL race bearings. My head consists of a Drag Cartel PNP k24a2 head with +1 intake valves and supertech flat face valves, and IPS KSC v2 cams. My boost will be around 17 psi coming from a Magnum Powers MPX90 supercharger. And exhaust will be exiting via an ASP header with 3" outlet into a 3" Go Power exhaust.
Now for the questions: (I'm blue in the face from searching)
1) With the sleeved block, I cannot use the coolant divertor that is used for the a2 head, right? If not, hope I don't have coolant problems.
2) What head gasket do I need to use? I've searched and some say k24a2 and some say k24a1 even though I have a k24a8
3) Since the Manley pistons are really meant for a frank build, should my motor be safe at 50* timing advance or should I get a limiter pin?
4) Also, should I see more or less than 11.5:1 compression using frank pistons in a full k24? Hopefully less
All advice and info is greatly appreciated!
Here's a link to my build thread... http://www.8thcivic.com/forums/engi...-mpx90-supercharged-build-what-you-think.html
