i started my swap tonight, and my main goal is to keep power steering and a\c. So its still possible with to keep a\c you will also need custom lines.JOHN said:Has anyone atempted this it gets hella hot here in Tx. If not I guess I will have to be the first. Got any ideas?
In my DC2, I kept both AC and P/S. AC lines were fabricated by a machine shop. It was easier and cheaper to do then trying to figure out how to mix and match. Plus, I was able to route the line the way I wanted to. Pics coming sometime next week.fearless_dsm said:I forget where I read it,but you can keep the a/c with a mix and match of a/c lines from various other honda's.
The p/s pump wont clear the stock hood line though.You will either have to get an aftermarket hood and clearance the supports,which still may not provide enough clearance,or fab a new bracket for the pump which mounts it lower,and run custom lines.
Luder94 said:In my DC2, I kept both AC and P/S. AC lines were fabricated by a machine shop. It was easier and cheaper to do then trying to figure out how to mix and match. Plus, I was able to route the line the way I wanted to. Pics coming sometime next week.fearless_dsm said:I forget where I read it,but you can keep the a/c with a mix and match of a/c lines from various other honda's.
