1 - 17 of 17 Posts
Just decided to stop with this project because I'm tight on time. I'll have pics up asap, local pick up is prefered in 323 area but I will ship at buyers expense. Rundown on this, is the mains weren't measured out and caused piston slap.
K24A4 bare block that needs some cylinder wall work on cylinders 1 and 4, will come with OEM headgasket 200
Fresh rebuilt K24A4 head, valve seats and seals are new 300
Wiseco Custom Pistons, NOT Shelf Pistons 12:5:1 87.5 Pistons/Rings/Locks/wrist Pins with BP H-Beam rods. Have about 10 miles on them and 2 of the pistons are brand new. 850
Pretty much new K24A4 crank aswell, same about 10 miles on it 250
Used K24 crank, spun a rod bearing, easy fix 100
http://www.k20a.org/forum/showthread.php?t=48229
Type-S Oil Pump set up w/ chain 150
Type-S Oil Cooler setup with water housing/pump 150
RBC Manifold, uncut w/ tb spacer 225
BP Headstud bolts 120
K24 Timing Cover 50
K Valve Cover 50 or Free with the head
Box of random stuff
K24A4 oil pan 50
what crank is that in the pic
1 - 17 of 17 Posts
