Hey Guys
So, I'm in a position where I need a "fresh" block, and I'm also doing a mild rebuild (new rings/bearings/seals/etc.). this gives me an opportunity to get a k24a2 bottom end if I so choose, since they're not that uncommon at wrecker yards where I live. I've looked into some of the other posts on this matter, but I'm still a bit unsure as to if 10.5:1 pistons would be pushing it on my sort of turbo build. the main reason I want to go this route is for gas mileage and torque
Here's the rundown of my setup:
My overall goal for the car is to have a strong powerband with lots of low end torque. Keep in mind, This is a daily driver that spends most of its time either cruising on the highway, or in low speed traffic. I have no plans to track the car
How safe will 10.5:1 be under these conditions? my main concern would be LSPE, but I'm not sure how much of an issue that it on our motors
- I'll be reusing the RAA valvetrain and head (I have perfectly good reasons for this)
- 6800 RPM redline
- MSR GT2871r rep turbo
- It will be run on pump gas at <10 PSI day to day
- Max boost it will potentially run is 15 PSI
