1 - 2 of 2 Posts
What will be the base map for this car at this point. Or what do you have to change on the base map to made the car run better ?
96 civic HX K24a
If the engine is stock and you have flashpro you should be able to upload a tsx k24 base map that should get you by until you can have a proper tune. If your o2 sensors are working the computer should make adjustments to hit close to its tArget air fuel ratios and keep the motor safe enough assuming you don’t beat on it.
1 - 2 of 2 Posts
