1 - 7 of 7 Posts
Is anyone running 88mm on stock walls. I had 12.5 87.5's but 2 of my cylinders got messed up, so now having to go bigger and hopefully needing 88 at most with out sleeving.
So looking to see if anyone is running this as a daily driver, pros and cons
You should not have any problems with 88 on a stock block. This is the exact reason we normally recommend people the 87.5s when they have stock blocks. If anything ever happens they can always step up to a 88 an not need to sleeve the block. :)
-Robby
how did 2 of your cylinders get messed up.
1 - 7 of 7 Posts
